Configure MLD Globally
Use the following procedure to configure MLD parameters for the switch.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6 MLD.
  3. Select the Globals tab.
  4. Configure the MLD global parameters as required.
  5. Select Apply to save the changes.
  6. Select Refresh to update the changes.
Globals Field Description
Use the data in the following table to use the Globals tab.
Field
Description
GenerateTrap
Enables MLD to generate traps.
GenerateLog
Enables MLD to generate logs.
